Hey,
I’m looking for the absolutely smallest Micro ATX case that can fit a normal atx power supply and has a 5.25 inch bay.
No GPU, no pci etc just the motherboard.
i’ve looked around quite a bit but they are all either quite large or cost more than this entire system that I plan on using.. 😁
It’s a dos pc with no hdd etc just floppy and I want a small case for it🕺🏻
Does anyone know such a case or uses one? Let me know !
https://linustechtips.com/topic/1189722-small-matx-case/
Silverstone makes small HTPC cases that might fit your needs, suck as the ML03 or ML04
https://www.amazon.com/Silverstone-Aluminum-Front-Center-ML04B/dp/B00DL4BMRC
https://linustechtips.com/topic/1189722-small-matx-case/#findComment-13568458
Cool thanks,
I’ll take a look at both and think about it. Rn I have to fix an issue with my cpu first
https://linustechtips.com/topic/1189722-small-matx-case/#findComment-13580423
