5 minutes ago, Unabless said:
I have amd ryzen 7 2700x and rtx 2060 6gb I am playing rust and I have only 90-100 fps graphic quality 2 whatever I put graphic quality always 90-100 before on gtx 1060 3gb I had like 120-160 fps what is the problem?
Are u sure it's in the right PCIe slot ?
Check ur temperatures during load
if they are okay try to DDU the graphics driver in safe mode and reinstall.
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
https://linustechtips.com/topic/1188233-low-fps/#findComment-13555919
Just now, Unabless said:
yes it is at pcie 3.0 x16 during the load of game temperature is at 56 celsius
U have to DDU the driver in safe mode ..
did u reinstall the graphics driver after upgrading the gpu ?
https://linustechtips.com/topic/1188233-low-fps/#findComment-13555930
9 minutes ago, Unabless said:
I did reinstalled graphic drviers
Try to DDU it
it's fairly easy
and download the newest driver for the rtx 2060 and reinstall it after ddu
https://linustechtips.com/topic/1188233-low-fps/#findComment-13555968
2 minutes ago, Unabless said:
I did no changes
go into nvidia control panel and make sure that the display is running at it's proper refresh rate ...
also check your display settings in game
https://linustechtips.com/topic/1188233-low-fps/#findComment-13555998
It is i putted high performance and everything dispaly s running at proper refresh rate 144 hz
https://linustechtips.com/topic/1188233-low-fps/#findComment-13556003
Can u run dxdiag and paste the log here ?
https://linustechtips.com/topic/1188233-low-fps/#findComment-13556006
not all the log
just the system and display stuff
https://linustechtips.com/topic/1188233-low-fps/#findComment-13556008
it may be a problem with windows .... ( it happened to many people before you )
so as a last resort try to reset windows ...
after backing up your files to another driver or partition ( anything other than the boot drive )
https://linustechtips.com/topic/1188233-low-fps/#findComment-13556010
Be sure to disable vsync
https://linustechtips.com/topic/1188233-low-fps/#findComment-13556017
