So the build I’m doing is a game / stream rig
(That will game on 1080p and stream on Very High720p)
my system is going to be run on a
Ryzen 3600
Mobo - MSI Tomahawk Max
but picking my GPU is kinda weird because. Initially I was going to go for a Gigabyte GTX 2060 OC 6GB , but then some one also mentioned to think about getting a MSI Radeon RX 5700 XT 8 GB MECH OC instead.
I picked to go with the 2060 because NVENC but than people say the extra 2 GBs that the 5700XT has makes a difference. Soo Im not sure what to do
https://linustechtips.com/topic/1187494-question-pls-help/
16 minutes ago, NZgamer said:
Get the 2060 because of NVENC
Yea, agreed at that res i don't see 6 GB becoming a bottleneck. My sister has a 1060 6GB on 1080p, she hasn't had any issues.
CPU Intel i7 4790K - Motherboard MSI Z97 Gaming 5 - RAM Cosair Vengeance Pro 32 GB @2400Mhz - GPU Asus ROG 980 Matrix Platnium x2 - Case Coolermaster HAF XB Evo - Storage Samsung 500GB Evo SSD x2 in RAID 0 + Seagate Barracuda 2TB 7200 x2 in RAID 0 - PSU Corsair RM1000
https://linustechtips.com/topic/1187494-question-pls-help/#findComment-13551023
Why are people still thinking NVENC is such a great thing? It's literally the same performance and quality as AMD's VCN on the 5700 XT right now, and unless you're using some really obscure streaming program, is equally as supported by software now.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1187494-question-pls-help/#findComment-13552528
18 minutes ago, NZgamer said:
*Posted 2 years ago
That was before the 5700 series was even announced.
https://linustechtips.com/topic/1187494-question-pls-help/#findComment-13552617
I think that if AMD's encoder was better than NVIDIA's it would be more well known fact
I never once said it was better. I said it was equivalent in all meaningful ways. Nvidia shills (they are very real, and you're using all their arguments) have been spounting issues in the AMD drivers that were patched over 6 months ago as reasons to buy Nvidia instead, and people generally fall for it, even the big name youtubers that review the tech. (who are also not representative of the majority of users)
https://linustechtips.com/topic/1187494-question-pls-help/#findComment-13555509
My point is, that if AMD's encoder was equivalent it would be a more well known fact. Come to this forum and ask for a build list and say that you're streaming and you'll be pointed straight to Nvidia.
Well know does not make something a fact. Less known does not make something false. You assume that VCN 2.0 would be more common knowledge, but the vast majority of people don't actually pay attention to this stuff, even on tech forums.
https://linustechtips.com/topic/1187494-question-pls-help/#findComment-13555825
