Heyo, I recently started to play RLCraft with some mates and I saw I was only getting 50fps on the game with shaders and optifine installed. I have a i7-7700k at stock, and a gtx 1080 strix. My CPU is only using 30% and same with my GPU. Is there anything I can do to fix that?
https://linustechtips.com/topic/1187141-minecraft-using-30-gpu-and-cpu/
is java updated ?
Try to install some optimization mods such as better fps or phosphor .
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
if u open task manager does it stress all cores at 30% or 1 or 2 cores at 100% and the rest are on idle ?
Your CPU is only at 30% because MC uses mainly one or two cores and the rest are at idle.
You'll notice there's a core probably near 100%.
https://gyazo.com/cab598debf686a9697af75dea11b6c2e
but surely id get more then 30fps in game with a 1080 and i7?
Yeah you should probably reinstall java as well as MC.
24 minutes ago, Oberfail said:
Thats normal for RLCraft. Its a very heavy modpack.
Try lowering your graphics settings and turning on the stuff under performance in the video settings.
Yup also the render distance ( the most important)
set it to 10 chunks max
