Will a 200w power supply handle 750 ti plus i3-2120 ?
dpers
yes No problem,it doesn't even need a direct power from the power supply >>> reference one only
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
Which 750Ti?
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
@dpers
200 watts should be enough  providing no overclock on GPU and CPU. Also plenty of ventilation as I presume it is a small form factor case.
Here is the link to Nvidia's Website on specs and required power.
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-750-ti/specifications
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
You can get good SFX PSUs for cheap as well as a CX430 for 25$. Why risk with such low power?
In portugal that power supply cost 40 euros and the money is tight
I would assume that in a prebuilt machine, they would have certified that everything is fully functional before they brought it to market..
Regardless, 200W should be plenty for an i3 and a 750ti, just as long as you don't have a ton of 10000 RPM HDDs and have an aggressive OC on the CPU and GPU..
i7 not perfectly stable at 4.4.. #firstworldproblems
You are really pushing it across the edge, it might work but no guarantee. Especially in the long run.
Listen if you care.
I always say this I can't understand why people would jeopardize those parts and not wait a week or two for a bit more cash.
Still learning how to play Dota 2 :)
getting a cheap psu from a prebuilt system and adding to it is one of the worst things you can do. 200w is fine, but does it actually give 200w?
It's better to spend a bit more knowing that the PSU is reliable than spending nothing on it and lots on a GPU, then it blowing up and frying the components.
then you're out on a GPU AND a PSU. (maybe more)
I'm sure the 750ti costs a fair amount so you should be able to afford a slightly more reliable PSU with that money.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
Because we are students and the case i think only takes the like the mini power supplys
I'm sure you can find something man, I dont really know much about mini PSU's but a few extra euros can go a long way in terms of safety. Or think of it this way, do you really want your pc to be like one of those upside down triangle body builders?
I would be weary of that psu. How old is it? Open it up and have a look at all the components. Look for any signs of damage (i.e. plastic starting to melt or sag). Remove any dust if there is any. Lots of dust would make me feel more weary too.
The thing is, it will work but you are going to be pushing close to 200W when you play demanding games. The cpu & gpu will be pushing out around 125W @ full load. 1 x HDD will be approx 10W. That with 2 - 3 fans with maybe 5W each will be around 150W in total.
Now you don't want to be pushing your psu to 200W either so you should be okay at the 150W limit but adding anything else and you will have a problem. I would use it for now, but start saving for a new one now! (or second hand one that is from a reputable brand)
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
