Hi,
I just finished building my PC and installed windows. Everytime the PC turns on I hear a clicking sound. It's like a metronome, not a sharp click but like a digitally sounding click. Yes I know it's a weird description but there we go. Now I suspected it coming from the Harddrive, a Seagate Barracuda 2TB, although I am not sure, but it is the most likely component. However nothing is installed on the HDD and I just formatted it now for storage, as windows is installed on my SSD. I did a test writing some massive text documents to and from the drive and the clicking didnt occour. I havent actually had any problems with the hard drive so far either. I store all my main data on the cloud, and I only keep applications (which I can reinstall if the drive fails) on the drive itself. Is it safe to carry on using the drive?
https://linustechtips.com/topic/1184863-clicking-noise/
43 minutes ago, lafrente said:
Some PSU's have a relay switch that makes a click when the pc is turned on and off.
Indeed mine has this, but this sound is much more defined and sharp. The sound I suspect from the hardrive seems to be more faint and a slightly digital sounding noise.
https://linustechtips.com/topic/1184863-clicking-noise/#findComment-13531554
