Deepcool matrexx 30 case fan config?
Solved by TVwazhere,
8 hours ago, 5NibbaHertz said:i know the case isn't that great for fans but can you suggest how many fans should i get and where should i put them in the case?
Well, the case can only support an additional 120mm fan at the front, so it makes it really easy to say "Put one additional fan at the front"
Featured Topics
SketchNI ·
Posted in Programs, Apps and Websites1 -
FI Fheonix ·
Posted in Storage Devices0 -
Shuyaib007 ·
Posted in Audio1 -
17
Sanedish ·
Posted in Troubleshooting0 -
surjava ·
BytePunk ·
Posted in New Builds and Planning2 -
1
