Do Fans need to be attached to case and CPU to cool or do you just need case fans?
Solved by Semper,
If you have a heatsink on your CPU, it will need a fan, unless it's purpose built to be a passive cooler.
If you have your computer in a chassis (as opposed to an open air bench, for example) chassis fans are highly encouraged. Poor airflow will lead to increased temperatures. Increased temperatures will result in throttling to protect itself. Throttling will lead to lower performance. As a whole, undue heat stress will add to the wear and tear of temperature-sensitive components.
