How much will it bottleneck?
Solved by .Apex.,
2 minutes ago, Theincha said:I think i will stick to this gpu for atleast the end of the year. For csgo, valorant, pubg lite and league of legends i think its good.What do you guys think?
Yeah definitely, that's what I'd recommend as well, wait for the new GPUs to drop this year to upgrade, the GTX 1050 should be fine for what you want to play, or keep it if that's all you play.
