Just now, Flaxe said:
No, I'm just going to go into the BIOS and set the speeds to what its advertised. And its 2x8 gb
then going for it is kinda pointless considering that Ryzen 3k really cant run that without unlocking IF from ramspeed and changing it to 2:1.
it tops out around 3600-3800mhz depending on silicon lottery.
https://linustechtips.com/topic/1181653-help/#findComment-13509085
Just get 3600Mhz
AMD themselves says it's the sweet spot, and more than that gets expensive quick while not giving much performance.
Linus made a nice AMD RAM speed video if you want to watch:
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1181653-help/#findComment-13509094
I got lost at ramspeed, so should I just get something like a 3600 mhz kit?
https://linustechtips.com/topic/1181653-help/#findComment-13509097
53 minutes ago, Flaxe said:
So, i'm building a pc with the ryzen 5 3600, so is getting a 4000 mhz ram worth it? Because I thought it gets downgraded or something because the cpu can't utilize those speeds. So im now thinking of getting a 3600 mhz kit.
I personally went for 3600Mhz, idk i feel like 4000 is somewhat overkill for a Ryzen3600 (I have the 3600X)
https://linustechtips.com/topic/1181653-help/#findComment-13509318
