3 minutes ago, Doggo lover said:
I was recorrding some games with obs and tried to import it into premier 2020 and when i dragged it into the bin it just said,
i am using default settings and stuff and it dosnet say what the problem is =(.
^Says the problem pretty well. Premiere probably doesn't support MKV.
In OBS, Press File > Remux Recordings. First choose the recordings you want to remux and then press the remux button.
Shouldn't take (much) more than a couple seconds per recording
Now try to import these MP4's in Premiere.
10 minutes ago, Doggo lover said:
thanks so much, is there a way to do this in the settings so i don't have to do it every time?
In Settings > Output > Recording you can choose the 'recording format'.
You can choose MP4 there, which does give a warning:
So you can choose MP4 recording, keeping in mind that warning, or you can keep using MKV and remuxing the recording (by dragging & dropping multiple files in the remux window you can remux multiple recordings at once).
