So when i changed my case fans i didn't even realize but i saw like a week ago that my side panel got cracked.Now it doesn't bother me so im not gonna go out my way changing my side panel but im just worried that one day im gaming and my fucking side panel explodes.
So can this happen? Can my side panel explode?
💠Case: SilentiumPC Signum SG7V EVO TG ARGB
💠Processor: AMD Ryzen 9 5900x
💠Graphics Card: ASUS TUF RTX 4070 OC
💠RAM: 32 GB Corsair Vengeance RGB PRO @ 3600 CL18
💠CPU Cooler:NZXT KRAKEN Z73
💠Power Supply: Corsair CX750 (750W)
💠HDD: 1 TB WD Blue
💠SSD 1: 240GB Kingston A400
💠SSD 2: 960GB Kingston A400
💠Motherboard: ASUS TUF B450M PLUS GAMING
https://linustechtips.com/topic/1180320-my-side-panel-cracked-can-it-explode/
Loosen the screw to reduce the tension on the glass,
Did you use a screwdriver?
I only use my fingers to tighten those screws.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
I wasn't the one replacing my fans, but i know indeed the screws are not as tight as they were and he did use a screwdriver
💠HDD: 1 TB WD Blue
As long as the tension in the area is reduced to a minimum it will be fine,
You may have to loosen the screw in this area to reduce the pressure on the glass.
What happened is that the screws were extremely overtightened,the glass could not handle the pressure and cracked.
2 minutes ago, Perrin said:
You can put a clear glue or tape to keep the cracks from going farther and no it shouldn't explode, but it could crack worse and eventually break when you take it off or sumn
I've had this crack for probably 2 months now and the cracks stood in the same place ill probably put some tape only if i see them expand A LOT.I hope that's a pretty good idea idk
💠HDD: 1 TB WD Blue
As long as there is no pressure on that area it will stay in the same condition as it is now.
Tape will be useless,It will do nothing to prevent such a scenario.
Alright well again as i said i've had this crack for about 2 months and it hasn't expanded atleast i don't think so but if i catch it expand i will loosen the screws.I hope THIS is a good idea
💠HDD: 1 TB WD Blue
No no,don't loosen all the screws,loosen only the screw in that area.
Obviously
💠HDD: 1 TB WD Blue
For a moment i thought you were going kamikaze there.
Alright well i'll just leave it like this but if i see some new cracks appear in like the same area or the cracks getting bigger i will loosen the screw in that area tbh i'm really young rn so i don't really have the tools i need nor do i believe in myself to do anything physical in my pc but i'll just hope the screw in that area isn't that tight
💠HDD: 1 TB WD Blue
So i can go play some games for this pc's lifetime without worrying it exploding like the creepers from mc?
💠HDD: 1 TB WD Blue
This is why I hate tempered glass side panels.
Acrylic panels might scratch much easier but you won't have a glass accident randomly which HAS happened (I remember one user recently had the TG panel shatter by putting it on his chair).
I bought my Fractal 7 XL with a solid side panel precisely because of that.  If I want a TG panel later I can just order it from them when the human malware allows supply to start coming through.
Due to the structure of glass - when compromised it triggers a destructive chain reaction,the severity depends on the force of the impact,
and in big glass panels there are weak spots that if hit - will shatter.
