7 minutes ago, Bmh20 said:
Hello, I am looking for a case for my first pc build. I live in the United States and i would like to be under $115. I need a ATX Mid Tower size
https://pcpartpicker.com/products/case/#t=3&X=0,11519
Quite a few options. :)
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497123
4 minutes ago, Bmh20 said:
I also forgot to mention that I want a mesh front
The Fractal Design Meshify C should fit that requirement: https://pcpartpicker.com/product/Y6Crxr/fractal-design-meshify-c-atx-mid-tower-case-fd-ca-mesh-c-bko-tg
Maybe the Cooler Master MasterBox Q500L: https://pcpartpicker.com/product/jG7v6h/cooler-master-masterbox-q500l-atx-mid-tower-case-mcb-q500l-kann-s00
Personally, I like the look of both. Might use one of them when I buy a new case.
Go through the original list and see which have what you want. It's a place to start.
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497143
What if i said i want one with RGB fans
That's outside my wheelhouse. Personally, I'm anti-RGB so I don't keep up with what has what. Check the list I originally posted. Some might have RGB. Some won't. Lack of RGB makes production cheaper. You can always add your own with fans, etc.
There should be other readers who can chime in with advice on good RGB cases at your price point. :)
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497162
do you need an rgb controller? Or does your mobo have enough rgb pins?
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497163
1 minute ago, Bmh20 said:
my mobo should have enough pins
for how many fans? Could you give me the mobo just to double check?
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497175
This one has a rgb controller. Use it  you could short circuit the fans at least because of a difference of voltage between the mobo ports and the fans rgb voltage.  Your fans are 5v your mobo is 12v. When building plug sata into the controller to power it. My friend used it in his build and he loved it. Have fun building! Glad I could help!
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497195
1 minute ago, WambleCropped said:
This one has a rgb controller. Use it  you could short circuit the fans at least because of a difference of voltage between the mobo ports and the fans rgb voltage. When building plug sata into the controller to power it. My friend used it in his build and he loved it. Have fun building! Glad I could help!
Which one is it?
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497204
Just now, Bmh20 said:
Which one is it?
use the rgb controller included with the case. buy it from newegg, i think the rgb controller only is shipped from that site
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497209
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497220
Hey there. If the Fractal Design Meshify C doesn't do it for you, perhaps the Cooler Master MasterCase H500 will?
Specifications:
Cooler Master MasterCase H500 ($119.99 on Newegg, Amazon)
  • Size (H x W x D): 19.76" x 8.98" x 20.67".
  • Motherboard Compatibility: Mini-ITX, Micro-ATX, ATX.
  • Front Ports: 2 x USB 3.0, 2 x USB 2.0, Audio In/Out.
  • Included Fans: 2 x 120mm RGB fans, 1 x 120mm fan.
  • Max CPU Cooler Clearance: 167mm.
  • Max GPU Clearance: 410mm.
  • Max PSU Clearance: 224mm.
  • Drive Bays: 2 x 3.5"/2.5" drive bays, 2 x 2.5" drive bays.
  • Other Features: Mesh or acrylic front panel option (both included), good thermals.
It is $4.99 over your budget right now, but it has gone for $109.99 in the past, and you might be able to snag it at a discount if you watch for price drops.
Price History:
Thermal Testing & Noise Levels:
Thermal Testing (CPU Torture Test)
Thermal Testing (GPU Torture Test)
Noise Levels
TLDR: Decent thermals (good performance, considering its price), but a little on the loud side.
SourceCooler Master H500 Case Review by GamersNexus.
正直に生きる、一度きりの人生だから
Keeb Weeb LinksCustom Mechanical Keyboards | #KeebWeebClub
'Chew Builds: Hoshī (PC) | Okashī (PC) | K-4398 (Keeb) | Eighty #391 (Keeb) | R2-968 (Keeb) | MGK64 (Keeb)
https://linustechtips.com/topic/1180106-choosing-a-case/#findComment-13497221
