Ryzen 3600 Thermal Issues with Dark Rock 4
Solved by jctappel67,
3 hours ago, Demonic Donut said:Why did you go with a thermal pad instead of paste? I haven't heard great things about them...
I haven't heard anything negative about Carbonaut from Thermal Grizzly.
So far, I just did a Cinebench R20 that ran throughn it twice, temps never exceeded 71 C with my custom fan curve. Right now I've got it running FAH, a steady 73 C, at 4 GHz all cores from PBO, 1.3Vish. With the GPU also folding, and kicking off loads of its own heat.
So far I'm happy. Will let it run for a bit, and might set the fan curve to the stock quiet fan curve later.
Edit: Just had it fold for over 2 hours. Maximum temperature was 77 C. I am happy with that, since FAH seems to be a special kind of torture for CPUs...
