Hi!
I've just put together a new build.
Motherboard: msi b450i gaming plus ac
cpu: AMD Ryzen 5 3600
gpu: gtx 750ti
ram: CMK32GX4M2B3200C16
At first It booted but didn't get any signal to the monitor. So I unplugged everything and tried again, same thing. Tried using only one of the memory sticks and got It working, updated the last bios and tried using both sticks again, same problem...
The one stick that works, works in both of the memory slots. The other one doesn't work in either. I bought the ram from a guy I know and he sent me print of It running in his PC.
So I check the motherboards qvl list, It says CMK32GX4M2B3200C16 is compatible, but a different version of them (an older one).
Should I just buy myself a new couple of rams or is there a way to get this to work?
Best regards
Mattias
https://linustechtips.com/topic/1177990-new-pc-build-memory-problem/
That sounds like a bad stick of RAM, you should grab a new kit.
I'd also suggest a new GPU...
F@H    EOC
Folding Rigs
Toaster Oven: RTX 3070 Ti & R5 7700X
Meth-Uselah: RTX 2070S & R5 3600X
Pecan't Pi: Raspberry Pi 5
ZZ Laptop: Asus ROG Zephyrus G15
Try to setup ram as not linked - MSI Bios has option for that (don't ask where - somewhere in OC section if you enable advanced). It will be not optimal, but you may test if it work that way.
But if second ram don't work at all (even without first stick) then it's ram stick problem, not type of ram.
90% of the time it's the ram try one by one and see if they appear in bios.
Had exact problem my friend and myself had with ryzen builds
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
