2 minutes ago, JarredFeutrill said:
I want to Clean the i5-3470 CPU in my dell optiplex 3010 what's the best way to Clean it and what is the best thermal paste to use?
Alcohol and a paper towel is best, second best would be water and paper towel and letting it thoroughly dry  before using it again.
The are loads of different thermal paste options, but for a non-overclocking CPU I would not pick something super expensive. Get something like MX-4
https://linustechtips.com/topic/1177692-how-to-clean-a-cpu/#findComment-13479121
Wipe the old paste off with alcohol and toilet paper, then give it a final wipe with a lint free cloth.
Some good options would be MX-4 or NT-H1. The difference between a decent thermal paste and a very high-end one is only a few degrees generally, so unless you're trying to get the most out of a CPU with overclocking (which isn't the case with your 3470) it's really not worth overspending on thermal paste.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1177692-how-to-clean-a-cpu/#findComment-13479127
