https://linustechtips.com/topic/1177639-new-build-help/
2 minutes ago, NZgamer said:
You have your PCPP set to USA, I highly recommend that you change it to Australia for Australian prices. US pricing is vastly cheaper than anywhere else.
And also I agree with @boggy77, Ryzen offers better value.
I am in agreement here as well.
@boggy77 Australia prices are nearly a 1100 more...
PCPartPicker Part List
CPU: Intel Core i7-9700K 3.6 GHz 8-Core Processor  ($669.00 @ Computer Alliance)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($129.00 @ PCCaseGear)
Motherboard: Gigabyte Z390 AORUS PRO WIFI ATX LGA1151 Motherboard  ($375.00 @ Shopping Express)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory
Storage: Samsung 850 EVO-Series 120 GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($59.00 @ Computer Alliance)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB BLACK GAMING Video Card  ($1347.00 @ I-Tech)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($75.00 @ BudgetPC)
Power Supply: XFX TS 750 W 80+ Gold Certified ATX Power Supply
Optical Drive: LG GH24NSC0 DVD/CD Writer
Total: $2654.00
Generated by PCPartPicker 2020-04-14 17:55 AEST+1000
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
https://linustechtips.com/topic/1177639-new-build-help/#findComment-13478717
Definitely go Ryzen.
Also I'd say get a bigger SSD. Even if you only go up to 240GB which is barely a price increase, it's way worth it; 120GB will fit the OS and not too much else. What resolution and refresh rate is his monitor? I might even say step down to a 2070, ditch the hard drive (or keep it if he needs the space) and go for a 1TB SSD.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/1177639-new-build-help/#findComment-13478728
9 minutes ago, B0yBlu3 said:
Sorry He will, just copying and pasting convo, thanks all for the quick replies.
He REALLY should go Ryzen. A 3700X is better than the 9700K in almost every way possible. It runs cooler, uses less power, has more security, performs the same in games and much better in most other applications. Not to mention Ryzen has an upgrade path as there are a bunch more CPUs coming out soon so he'll be able to upgrade to a 16 core 4950X later whereas 1151 is a dead socket
https://linustechtips.com/topic/1177639-new-build-help/#findComment-13478763
3 hours ago, B0yBlu3 said:
You can get away with a cheaper cooler such as an Arctic Freezer 34 esports duo.
A 5700XT is better value for money. Just get a good one like the Gigabyte Gaming OC, MSI Gaming X, Sapphire Red Devil or Sapphire Nitro etc.
A B450 motherboard is another place to save money. You have the MSI B450 Gaming Carbon AC which has wifi onboard, or you could go with an MSI B450 Tomahawk MAX and an adapter depending on the price difference.
Samsung SSD's are overpriced. You could get something like a Western Digital SN550 1TB or Crucial P1 1TB if this is just a gaming pc.
https://linustechtips.com/topic/1177639-new-build-help/#findComment-13479244
https://linustechtips.com/topic/1177639-new-build-help/#findComment-13479260
