18 hours ago, andrewmp6 said:
What size are both rads tho ?The define 7 xl looks nice.Other options are lian li o11 dynamic xl and phanteks enthoo 719
if i choose Define xl radiators  will be 420
if i choose Thermaltake A700 radiators will be 1x360 and 1x 420mm
https://linustechtips.com/topic/1176288-best-case/#findComment-13473999
Also depends on the radiator thickness.
The A700's 420 rad would probably have to be a standard 27mm thick, because with a fan it would extend towards whatever GPU you're using (examples of similar builds can be found on PC-O11D's).
The Define 7 XL doesnt have rad thicknesses listed, but based on past Define R6 builds I've seen it's likely you could do push/pull on front and top at least with slim rads, possibly one of them being a thicker variant (38mm, 55mm, 60mm)
https://linustechtips.com/topic/1176288-best-case/#findComment-13480489
The Define 7 XL doesnt have rad thicknesses listed, but based on past Define R6 builds I've seen it's likely you could do push/pull on front and top at least with slim rads, possibly one of them begin a thicker variant (38mm, 55mm, 60mm)
thank you very much for your help so now its on me to decide :)
https://linustechtips.com/topic/1176288-best-case/#findComment-13480855
the radiator is 45mm now can i do push pull ?
https://linustechtips.com/topic/1176288-best-case/#findComment-13480891
in the front of the case yes,The top i fully think you can also.That case is bigger then it looks,The core of it is a view 71 with new panels stuck on it.Now push pull on a 45mm rad is overkill to me,I would only go push pull on a 60mm or thicker but its up to you.
https://linustechtips.com/topic/1176288-best-case/#findComment-13482054
