I'm trying to make a toString methodthat returns a string made out of the elements of an arraylist with a for each loop but I'm getting an IndexOutOfBounds and I can't figure out why.
Heres and example of what I want to achieve:
String a = "{";
			for(int i=0;i<list.size();i++) {
				a = a + list.get(i);
				if(i!=list.size()-1)
					a = a + ",";
			return a+"}";
And heres my for-each loop:
String s = "{";
			for(int a: list) {
				s = s + list.get(a);
				if(a!=list.size())
					s = s + ",";
			return s+"}";
https://linustechtips.com/topic/1175976-need-help-with-for-each-loops-java/
@CreepyPro
A for-each loop takes out the interation that you are doing in the original for loop.  So when you say for (int a: list), that means a has the value at the index of the loop.   So you should only need to do s = s + a;  (or s += a; )
2 minutes ago, PyroTheWise said:
@CreepyPro
ohhhh, thanks for your help now it works
