i was just putting together my new computer and was about to put my cpu in when i removed the cover and noticed that there might be some pins missing or broken.  Its an MSI Mpower Motherboard so it was tested but all th images i find online show the socket differently. Is the Socket broken or is this how it's supposed to be?
https://linustechtips.com/topic/11744-help/
looking at that image now and it doesn't look the same to me. Towards the middle of the socket in the top right there is a gap of about 2 pins i think? i took a picture with my camera but i think the one i have up shows it better. here is the second picture i took. TIzQ71a.jpg
https://linustechtips.com/topic/11744-help/#findComment-125117
no hadn't put the cpu on it yet i opened the latch and removed the black plastic shroud that covers the socket and it was like this... i got a magnifying  glass and took a closer look and there are two pins that are bent, is it ok to bend them back or should i return the motherboard?
https://linustechtips.com/topic/11744-help/#findComment-125159
Its up to you, if you bend them back it might work, or you void the waranty.
I suggest you to contact the supplier and ask them what to do
Running: i7 4770k cooled by Swiftech H220 (Delided and Lapped) (5ghz+ capable) - MSI Z87 mPower MaX - 4x 4gb 2400mhz corsair vengeance cl10 - 660Ti Graphics in a Fractal R4
https://linustechtips.com/topic/11744-help/#findComment-125328
I wouldn't bend it because you might break the pin and possibly void your warranty. I would just RMA it if you don't want to mess with it.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/11744-help/#findComment-126528
