So i have an Alienware 15 r2 and i havent changed the thermal paste for over 2 years and i dont have any of that alcohol to remove the thermal paste, will it be ok to use a: tissues, cotton swabs or micro fibre cloth.
If none of these are options, can i just put thermal paste on top of the old one. because gtx 970m isn't that great anymore
Pc value: 9999999$. Alienware 15 r2: 16GB Ram ddr3, Intel Core i-7 4110HQ @ 3.5ghz, gtx 970m, 1 TB HDD *for games*, 120GB SSD *for windows*.
fastest boot time, 6.5 seconds
https://linustechtips.com/topic/1174142-removing-thermal-paste-help/
cotton with a very small amount of water (or dry if oyu don't feel comfortable), also if you have cleaning alcohol, use that
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
i havent got any cleaning alcohol, so it'd be safe to use cotton swab for gpu and cpu and the heatsink?
you can use goo gone, alchol based hand sanitizer or nail polish remover. wipe it a few times with a paper towel or something like that, then wipe with a coffee filter to completely remove it. ltt did a video on it
Either @piratemonkey or quote me when responding to me
Alright thank you alot :D
When dry all these methods will leave some residue, so try to remove that after removing the thermal paste...
Maybe a tissue will leave less crap behind
Laptop:
Photography:
Cameras:
35mm Film:
Lenses:
Meike MK-50mm ƒ/1.7
micro fibre cloth might be more useful than a tissue
Just now, UltraMagnus69r said:
Vodka and micro fiber worked like a charm for me once lol
Lmao can i do it without vodka?
Obviously make sure its out of the socket. I like microfiber that doesn't leave fuzz. The video above shows some pretty good alternatives. Just make sure that any liquid or cleaning pad doesn't leave anything on the CPU after cleaning
Noted, thanks!
it may be but you will have a hell of a time cleaning it, thermal paste is some nasty stuff
Laptop:
Photography:
Cameras:
35mm Film:
Lenses:
Meike MK-50mm ƒ/1.7
You should really invest in isopropyl alcohol. The higher the % the better.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
in the current state of time it's really hard to get isopropyl alcohol, i'll check with my local shops incase they sell them. Also what do the percentages mean? do i get 70%, 90% 99% 91% etc
Higher 90s would be best, it cleans better and leaves less residue.
Alright thanks
I personally use a napkin or paper towel. Isopropyl alcohol helps if it's caked on and cleans better but isn't usually necessary.
It satisfies my ocd 👌🏻
Im gonna order 99.9% isopropyl alcohol, i read that is the best one to use
