Case fans are okay, and gpu ones but cpu stopped dead. whats going on? was fine yesterday. my temps with the fan are 32 idle. closed a game just now on noticing at 60's. did my fan die?
main rig:
CPU: 8086k @ 4.00ghz-4.3 boost
PSU: 750 watt psu gold (Corsair rm750)
gpu:axle p106-100 6gbz msi p104-100 @ 1887+150mhz oc gpu clock, 10,012 memory clock*2(sli?) on prime w coffee lake igpu
Mobo: Z390 taichi ultimate
Ram: 2x8gb corsair vengence lpx @3000mhz speed
case: focus G black
OS: ubuntu 16.04.6, and umix 20.04
Cooler: mugen 5 rev b,
Storage: 860 evo 1tb/ 120 gb corsair force nvme 500
backup
8gb ram celeron laptop/860 evo 500gb
https://linustechtips.com/topic/1173726-cpu-fan-stopped-dead/
not even a year old.
main rig:
case: focus G black
backup
https://linustechtips.com/topic/1173726-cpu-fan-stopped-dead/#findComment-13448124
What fan and where is it plugged in? Make sure the fan speed isn't set too low.
Does the fan start spinning and without much resistance when you push on it?
FYI, you can use the Edit button to add in more info instead of making a separate post.
https://linustechtips.com/topic/1173726-cpu-fan-stopped-dead/#findComment-13448131
okay you were right, fan got loose. i move the pc a lot.
main rig:
case: focus G black
backup
https://linustechtips.com/topic/1173726-cpu-fan-stopped-dead/#findComment-13448138
