Do usb Headsets work with Pcs?
Go to solution Solved by mariushm,
Try right clicking on your speaker icon by the clock, select recording devices , and select the microphone. Right click and choose set as default or something like that.  After you restart applications, they should pick it up and use that microphone by default.
Or from various applications, make sure you go in their options/settings and select the actual microphone on your usb device.
I tried pluging in my usb headset and the audio worked but the mic did not. I tried all of my usb ports and I have my drivers installed. Do I need some sort of adapter?
Thank you for your time!
  • CPU
    AMD Ryzen 5 2600x 3.4 GHz 6-Core Processor
  • Motherboard
    Gigabyte B450 AORUS M Micro ATX AM4 Motherboard
  • RAM
    Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
  • GPU
    Gigabyte GeForce GTX 1660 6 GB GAMING OC Video Card
  • Case
    Thermaltake Versa H18 MicroATX Mini Tower Case
  • Storage
    Crucial MX500 500 GB 2.5" Solid State Drive
  • PSU
    Corsair VS 550 W 80+ Certified ATX Power Supply
  • Cooling
    Deepcool Gamerstorm Captain 240 PRO
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1173032-do-usb-headsets-work-with-pcs/
What Headset is it?
Usually they do work, yes
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
