Best gaming performance 10G network card advanced settings?
Shoonay
I've read a few "max network performance for gaming optimization" threads here and there, but there were none that specifically mentioned a 10G network card, so I'd like to ask here, are these the best settings?
Mine is a rather uncommon ASUS ROG AREION 10G PCI-e that I got from second hand (~$70), based on the Aquantia AQC-107 chip, updated to the newest drivers (2.1.20) and firmware (3.1.100) running under W10 x64 version 2004 OS build 19041.172
                     ARP Offload : Disabled
      Device Sleep On Disconnect : Disabled
             Direct Cache Access : Legacy Descriptor
               Downshift retries : Disabled
       Energy-Effiecent Ethernet : Disabled
                    Flow Control : Disabled
            Interrupt Moderation : Disabled
       Interrupt Moderation Rate : Off
           IPv4 Checksum Offload : Disabled
                    Jumbo Packet : 16348 Bytes
    Large Send Offload V1 (IPv4) : Disabled
    Large Send Offload V2 (IPv4) : Disabled
    Large Send Offload V2 (IPv6) : Disabled
                      Link Speed : Auto Negotiation
    Locally Administered Address : Not Present
            Log Link State Event : Enabled
    Maximum number of RSS Queues : 4 Queues
                      NS Offload : Disabled
                 Priority & VLAN : Priority & VLAN Enabled
                 Recieve Buffers : 4096
            Recieve Side Scaling : Enabled
  Recv Segment Coalescing (IPv4) : Disabled
 TCP/UDP Checksum Offload (IPv4) : Disabled
 TCP/UDP Checksum Offload (IPv6) : Disabled
                Transmit Buffers : 8184
                         VLAN ID : 0
               VLAN Monitor mode : Disabled
                   Wait for Link : Auto Detect
       Wake from power off state : Enabled
                    Wake on Link : Disabled
            Wake on Magic Packet : Disabled
           Wake on Pattern Match : Disabled
                    Wake on Ping : Disabled
Lowest latency to my router.
Like in these tutorials around the webs:
https://steamcommunity.com/sharedfiles/filedetails/?id=727946014
or
https://helpdesk.flexradio.com/hc/en-us/articles/202118518-Optimizing-Ethernet-Adapter-Settings-for-Maximum-Performance
But do these apply to a 10G NIC too or will severly impact the throughput? Not that I'm after troughpout that much, all I need is ~2.5GB (2 x 1Gbit NAS + 600Mbit fiber running at the same time), just asking.
