Top left is a female A-RGB connector (12v). Middle is a simarilar cable for RGB I think.  (4 pin), right is a female version of of what is on the left.
For the bottom photo. Left is D-RGB (5v addressable), middle is a 4 pin PWM cable (makes the fan go whooosh). Right is a male D-RGB (5v addressable) connector.
For D-RGB you have your motherboard to support it. That or get a controller for it. 12v addressable A-RGB is more common the D-RGB.
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
https://linustechtips.com/topic/1172663-2-diffrent-4pins-thing/#findComment-13439656
So looking at case specs, you have bit of issue here. First of all, you should always research parts before buying anything. While PC building side of things is easy, it requires research to learn what parts work together.
Case has 4pin 12V RGB. You've bought 3pin 5V ARGB fans to go with it. These two are NOT compatible directly with eachother. They can't use same connectors. The question becomes, did you want to sync everything and what is your motherboard? I think there might be some mobo's which support both 5V ARGB and 12V RGB at the same time, but I'm not 100% about it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1172663-2-diffrent-4pins-thing/#findComment-13442052
