Is Samsung SuperWide a worth replacement for 3x Ultrawides?
TheNaitsyrk
I ran out of space and I have this monitor in mind now:
https://displaysolutions.samsung.com/monitor/detail/1421/C49RG90
I was thinking to buy it and sell my 3x X34P from Acer. Opinions?
HDR1000 120Hz half the resolution of those 3 but without bezels and Freesync.
Main PC:
CPU: Intel Core i9 13900KS SP 116 (124P-102E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC8 1.525V (real voltage 1.425V + - Temps 85-90 P-Cores, 70-73 E-cores)
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8600Mhz CL38 (OC from 8000Mhz CL40)
GPU: RTX MSI 4090 Suprim X with EKWB waterblock
Case: My own case fabricated out of aluminium and wood
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
WiFi: BE202 WiFi 7 Tri-Band card module
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 240Hz Ver. 5120x1440 with G-Sync and Freesync Premium Pro 1008 Firmware Ver, and 1x Electriq USB C 1080p 15'8 inch IPS portable display for temperature and stats, MSI 23'8 144Hz G-Sync
Fan Controllers:  6x AquaComputer Octo with 5 temperature sensors
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3rd Loop: 1x 240mm PE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY)
Total: 5x pumps and 13x radiators 50x 3000RPM Noctua Industrial fans
Keyboard: Razer BlackWidow V3 RGB - Green switches
Sound: Logitech Z680 5.1 THX Certified 505W Speakers
Mouse: Razer Basilisk Ultimate Wireless with charging dock
Piano: Yamaha P155
Phone: Oppo Find X5 Pro
Camera: Logitech Brio Pro 4K
VR: Oculus Rift S
External SSD: 256GB Overclocking OS
LaptopMSI Titan GT77HX V13RTX 4090 175W, i9 13980HX OC: P-Cores 5.8Ghz 3 cores and 5.2Ghz 5 cores and E-Cores 4.3Ghz, 192GB of RAM @5600Mhz @3600 (chipset limit),
12TB (3x4TB) of NVMe, 17'3 inch 4K 144Hz MiniLED screen, 4x 17'3 ASUS portable USB-C Monitors 240Hz, Creative Sound Blaster G6 Sound Card, Portable 16TB NVMe in TB4 enclosures (8x2TB), Razer Basilisk Ultimate Wireless with charging dock gaming mouse, Keychron K3 gaming keyboard with blue switches low profile, Logitech Brio 4K Webcam.
Hand held: ROG Ally with XG Mobile RTX 3080 with Keychron K3 low profile keyboard (Blue Switches) and Razer Hyperspeed V3 mouse and 4TB NVMe upgrade (WDBlack SN850X), with 100W 20000Mah power bank and portable monitor ROG XG17AHP 17'3 inch 240Hz with built in battery, and 518Wh Power station for Camping.
Depends what you need the 3 monitors for, going to just 1 can impact that.
You keep asking about monitors, it's really the same answer as before... totally up to you and what you want.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
