Not that long ago, I got a graphics card from a friend and decided to test it’s performance in MSI Kombustor, after the first five minutes I got a lot of artifacts on my screen and needed to restart my Pc ( screenshot below ). A day before that I checked the graphics card for any physical damage and changed thermo past (screenshot below). What could be the problem, and are there any possible solutions besides buying a new graphics card ?
Tank you for your attention ))
https://linustechtips.com/topic/1172470-msi-970-artifacts-need-help/
Did you ask your friend if the card worked?
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
Seems like the card has an issue with VRAM, you could try downclocking it and see if it gets more stable but otherwise you can't fix something like this or at least it would cost more than the card to re-solder the chips.
Quote or Tag people so they know that you've replied.
