PC performing way below expectations
Solved by Meganter,
1 minute ago, Bryan Witherspoon said:Do I need a higher MHz if I'm only using my PC primarily for streaming & gaming on small games like Fortnite & Warzone & Etc..?
Not really, even on stock a 8700K is very capable to do any of that without problem and you have a 1080Ti so you can use Nvenc to offload task from the CPU to the GPU.
