Depends on CPU and the exact kits you're comparing
Desktop benching:
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13406101
DDR4 4000 CL20 has the same latency as DDR4 3600 CL18. What kits are you looking at?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13406115
31 minutes ago, ChrimsonRain said:
ryzen 7 3700x cpu and ?? on ram so far
Then you should focus on getting the greatest ratio of frequency to CAS latency instead, among 3600MHz+ kits.
Desktop benching:
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13406181
5 minutes ago, ChrimsonRain said:
exactly those the 4000s and the 3600s
4000 and 3600 are not memory kits, they are memory speeds. Corsair Vengeance LPX is an example of a memory kit. I was just pointing out that you could end up getting a good latency on a 4000MHz kit, even if the CL number is higher.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13406323
Just now, ChrimsonRain said:
corsair patriot and gskill , trident
Those are just brands. They're not kits.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13406331
Patriot Viper Steel Series DDR4 16GB (2 x 8GB) 4000MHz Performance Memory KitG.Skill TridentZ RGB Series 16GB (2 x 8GB) 288-Pin 3600MHz (PC4 28800) Desktop Memory Model F4-3600C17D-16GTZR
Those are a couple
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13406342
CL19 or CL20? I dont remember Patriot selling any CL20 4000MHz kit
Desktop benching:
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13406350
6 minutes ago, ChrimsonRain said:
TEAMGROUP T-Force Xcalibur RGB DDR4 16GB (2x8GB) 4000MHz (PC4-32000) CL18 Desktop Memory Module ram
i think these are what i'm considering the most
If you wont do any manual timings tuning, this will be the best though you'll not run them at 4000MHz, instead double that of FCLK which you have to test what your CPU is good for (anywhere from 1800MHz to 1900MHz)
If you do tune timings manually, then the Samsung B-dies in the Patriot kit are the best choice.
Desktop benching:
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13406398
48 minutes ago, ChrimsonRain said:
your correct they are cl 19
CL19 4000 is lower latency than 3600 CL18
Primary PC:
PSU tier list
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13406516
It is important to remember that Cas Latency is measured in Cycles, not time, so a higher CL number is not bad, if you have the clock speed to make up for it.
The latency (in nano seconds) is Cas Latency in cycles / Command speed in Hz * 1000 noting that for DDR Ram, Command Speed = Clock Speed / 2
Using the example above from Fasauceome we get:
  CL19@4000Hz has latency of  19 / (4000/2) * 1000 = 9.5ns
  CL18@3600Hz has latency of  18 / (3600/2) * 1000 = 10ns
This makes the DDR4-4000 CL19 just that little bit faster
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13410145
Want a fast kit? Get this one.
https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232472
I run this kit with my 8700K. It's fast. That's all I have to say.
And also, get the kit because that price is dirt cheap. They used to be 300$+
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13410168
DDR4-4000 MHz is freaking high frequency.
I don't think many CPUs will be able to achieve that...unless you got super lucky in the 'Silicon Lottery.'
Especially on Ryzen; their Integrated Memory Controller is not a robust as Intel's ... IMO.
I'd stick with a lower frequency DRAM kit, and go for CL14 or CL16.
For an example, DDR4-3200 MHz with CL14 latency timings.
You also pay a premium for DRAM binned for DDR4-4000+ MHz.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1168831-ram-speed-or-latency/#findComment-13410170
