Ultrawide or dual monitor
Jakabko95
I’d like upgrade my old monitor setup. Previously I had dual monitor setup of my old monitors but one of them died recently. I love Ultrawide displays and was looking for LG 34GK950F but it’s quite expensive. I also found LG 27GL850 and buying 2 of these would be even cheaper and could have even bigger work place. Which of these options is better and why or do you have better ideas?
Well, i'd say this way as long as you are more into doing work on your PC a ultra-wide monitor is the way to go, at least that's my opinion. In case you are into gaming, i'd say stick to two separate 16:9's - i used to game on a 21:9 and ultra-wide support in 2017 was a mixed bag, maybe it's better now.
Go with the 2 27's, unless your workflow is something like video where you'll benefit from an uninterupted timeline.
I'd only get an ultrawide if you could afford something like a 49".
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Significantly better. I've never ran into an issue.
I have a 34GK950F and here's my take on it.
Ultrawide is spectacular. I love it, I love gaming on it, I love productivity on it. And all in all that monitor is absolutely fucking fantastic, if you can afford it I highly recommend it.
The only cons I can think of are:
If you are a content creator, screen captures at 21:9 don't translate well to the 16:9 of youtube/twitch. I can show you some screenshots if you'd like, but you get little black bars to make it fit well. Not the end of the word for casual content, but it's a bit of a pain in the ass.
If I'm doing something like playing ESO, I like watching youtube/twitch in the background, and it would be nice to have a 2nd monitor, so down the road I'd possibly consider mounting another panel above it.
But in the mean time I absolutely LOVE the monitor.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Agreed. I haven't played a giant spectrum of games on it yet, but the only issue I've had is DS2 could only run at a standard 1440p, UW is not supported. But that's it, on a 2014 game..
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
I've been looking at the Asus itro xv340ckp. Most 21:9 monitors now have a screen set up interface so you can arrange the space into different sized virtual screens.
This, and what @dizmo said as well.
Almost 3 years with my AOC Agon now and wouldn't go back to 16:9 gaming.  I use 2x 27" monitors at my office, so I experience both.  Granted the 2 monitors are little more real estate than a 35' 21:9 but productivity at home is fine you just have to get used to the split screen vs duals.
Even in games where the peripheral views are stretched (and you don't get any advantage of viewing over a 16:9) I love the additional room for UI.  It just fills your view much better.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
When I had 2 monitors I used to play something on main monitor and watch stream/YouTube on my second monitor but could I do it also on 34GK950F ?
If you had choose between 34GK950F and dual 27GL850 what would you choose for gaming, watching streams, multi-tasking, etc..?
If you like having a game and a browser... being able to look at the browser without alt-tabbing out... get duals.  Tho you have to use windowed fullscreen I think.  I'm old enough to remember a sizeable performance hit for windowed vs fullscreen :)
If you can handle alt-tabbing inconvenience for a much larger main game in your face encompassing your life... then go UW.
IMO, nothing beats an UW for gaming except maybe a super UW, but I haven't used one yet.
For watching things too, a single larger screen beats 2 smallers in my book.
OnePlus:
Other Tech:
No you can't You could maybe awkwardly cram a windows game on half, and a browser on half, but it just isn't meant for that. You can easily divide windows, etc, but it doesn't work well with games.
But I still think UW is king.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
