1 minute ago, Budget gamerXD said:
Every time I use windows key+shift+s
I take a photo but it just copies to clipboard and it doesn't save in Pictures folder
How do I fix that
After you have made a screenshot using that command, you can click on the image in the Windows notification, open it like that and then press Ctrl+S to save it.
That is what I found to be the easiest to save the picture.
P.S. if you don't want to press the Windows+Shift+S combo, you can remap PrintScreen to it via the Windows Settings. If you go into Settings and search for 'Snip', open the result, scroll down you can toggle PrintScr. to do Win+Shift+S
https://linustechtips.com/topic/1166317-snip-sketch-help/#findComment-13385395
Is there any way that the picture saves automatically?
https://linustechtips.com/topic/1166317-snip-sketch-help/#findComment-13385409
No, that's not a feature yet.
Alternatively, you can turn on the clipboard history and then have access to all those snips by pressing WIN+V, and then pasting them in what ever program you need (even works on the forum, to paste a screenshot of something) ;
Settings > System > Clipboard
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1166317-snip-sketch-help/#findComment-13385852
