5 hours ago, kappawarrior said:
Hey guys i want to add some RGB fans and the ones that are in my price range connect via 3 pin 5V but I have only 4pin 12V on my MTB so are there any solutions to this I seemed to find one but i found only 1 review.
help pls :D
if you have only 4 pin and want to use your mb to control them just by 4 pin rgb fans.... there is an convector but its buggy and it just make the 3 pin act like the 4pin rgb anyway.
https://linustechtips.com/topic/1164792-rgb-problems/#findComment-13372991
5 hours ago, DominicNikon said:
3 pin fans will work on 4 pin headers and you can control them using voltage. what fans are you looking at?
hes talking about rgb vs argb not powering the fan...
https://linustechtips.com/topic/1164792-rgb-problems/#findComment-13372992
Check out Deep Cool RF120 5 pack, 5 RGB fans for $53.99. Using 4pin 12V header. Can be daisy-chained and just plug the last one into your motherboard. Also come with 2 PWM fan controller.
Edit: You said you can only afford 3pin 5V ARGB fans which actually confused me because those are more expensive than the old ones (4pin 12V RGB fans). If you have a small budget, those fans I linked above should work well for you.
https://linustechtips.com/topic/1164792-rgb-problems/#findComment-13381255
