1 minute ago, EL02 said:
Yeah...first and second gen ryzen (the AF does behave a lot like a 2600) cant really get such high frequencies. 3000 or 3200 may be doable.
what about dram calculator, the moment i use 3000 with its `SAFE` settings i get no post
dont use DRAM calculator, just apply DOCP/XMP and force 3000MHz
Desktop benching:
Did you refer to the motherboard to know which RAM slots to install into?
And Ryzen 2000 can absolutely run 3600MHz.  Maybe not all, but certainly enough.  Though the mobo may be what's holding OP back.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
I have my 2600 at 3200, wont post ant higher. But, not all that knowledge about OC'ing RAM
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
1 hour ago, A_Game_Hacker.b1368 said:
how do i force 3000MHz, do i just use XMP and change frequency to 3000?
yes
Desktop benching:
6 hours ago, A_Game_Hacker.b1368 said:
So im using a B450M/AC Mobo w/ 3600MHz Trident Z Neo. I use the specified speed, voltage and timings yet i either blue screen or dont get post. ryzen dram calculator doesn't help either
First: are the RAM sticks in slots A2-B2? :) (2nd and 4th slots counted from the CPU...)
If not, place them there.
Life is really challenging. I don't always suceed: )
