I have an EVGA GeForce GTX 1070 Ti FTW2. No overclocked applied until i play some games.
Control panel setting is "prefer maximum performance" on power (System power options at high performance as well) and texture filtering - quality setting is "high performance"
Here is a photo of idle temps just opened now. Do note one fans spins every 10-15 seconds due to the control panel settings...I assume.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1164705-are-these-temps-okay/
Yea? 60's is fine... Good even. Is that what your asking? Low 60's is fantastic!
Are these idle of load though? Usually idle the fans won't even spin... But if this is load, thats great!
https://linustechtips.com/topic/1164705-are-these-temps-okay/#findComment-13371730
Yeah, just making sure. I thought so. I just didn't know if I needed to re-paste or anything. However fantastic is fantastic. Thank you.
https://linustechtips.com/topic/1164705-are-these-temps-okay/#findComment-13371734
I'd suggest just using "Optimal Power" instead of "Prefer Maximum Performance" as it doesn't really make a difference in terms of performance in most games and your card won't be running in a higher power state at idle when it really doesn't need to. Your idle temps will most likely also drop if you change this.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1164705-are-these-temps-okay/#findComment-13371747
