so today i installed a long network cable to my new room. first a 25 meter one, then a extender thing (ethernet ports at both sides) then another 10 meter cable and everything is in cat 6 but I only got 130/40 mbps and I am paying for 250/100. i tested with my laptop and a 1 meter cable from the router and i got 230/80 and im fine with that. does the connection get so bad from 35 meter (kinda 35 yards) away?i think its a bit strange that it losses so much. what should i do?
https://linustechtips.com/topic/1164377-long-network-cable/
Per the electrical spec, it is rated for 100m. Below that and you'll have no issues* and above that it's in most cases just not going to work or cause a ton of errors. Can you link the extender you have? Something akin to this?:
https://smile.amazon.com/Inline-Coupler-AVACON-Ethernet-Female/dp/B07DWPW5MJ
*Provided no large source of EM radiation are present, damaged wires, etc.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1164377-long-network-cable/#findComment-13369109
You say that you tested with your laptop, does that imply that the 130/40 result was with a different computer? Or was the laptop the only computer used, but with the cable changed?
https://linustechtips.com/topic/1164377-long-network-cable/#findComment-13369174
Would very much rule out that coupler. That one in particular. Those are usually not that bad, but you've got something going on with the line.
I would:
1. Test each cable with the same PC, and see if they both produce same speeds. You shouldn't see a major difference between them. Not 100+ meg difference like you did before.
2. I'd then test the coupler with a new pair of cables.
Compare the two, and make your decision off of that.
Perfect world, you can run cat6 cables for up to 100m (~320ft). I would remove the coupler if, at all, possible.
"Soli Deo Gloria"
IT Technician by trade. Computer/Network equipment enthusiast!
Gaming PC:
  • AMD Ryzen 5 2600X (Stock Core Clock)
  • XFX RX 590 FATBOY 8 GB (Stock Core Clock)
  • Asus ROG Strix B450-F Motherboard
  • Crucial Ballistix 16 GB (2x8) kit 3200 Mhz RAM
  • 512 GB Intel 660p M.2 NVMe SSD (Boot & Current Games)
  • 3 TB Toshiba HDD @ 7,200 rpm (Data)
  • 2 TB Seagate HDD @ 7,200 rpm (Backup)
  • Corsair CX650M PSU
  • NZXT S340 Elite Case
  • 24" AOC C24G1 1500r Curved Gaming Monitor 144hz 1080p
  • Turtle Beach Stealth 450 Gaming Headset
  • Corsair K63 10-Keyless Mechanical Gaming Keyboard (Cherry MX)
  • Logitech G602 Wireless Gaming Mouse, Razor Death Adder
  • Win10 Home
PC Part Picker Link
https://linustechtips.com/topic/1164377-long-network-cable/#findComment-13369492
