I'm not a fan of RGB at all but I'm doing a build for a friend that wants it. I'm wondering if the Masterbox TD500 ARGB will work with the B450 GAMING PRO CARBON AC? I'm reading the manuals online and I can see that the motherboard has an ARGB LED Strip Connector called "JRAINBOW1". I assume "ARGB LED STRIPS" and "ARGB LED FANS" are interchangeable?
"The JRAINBOW1 connector supports up to 72 LEDs WS2812B Individually Addressable RGB LED strips (5V/Data/Ground) with the maximum power rating of 3A (5V)."
https://linustechtips.com/topic/1163900-regarding-argb-cases/
Yes the fans are compatible with motherboard software.
As a side note, there's a TD500 MESH version that I would highly recommend over the base version, as the base version's fans are basically useless how they're installed right now as they have nearly no access to air.
https://linustechtips.com/topic/1163900-regarding-argb-cases/#findComment-13364925
As I forgot to mention, they will be getting the mesh version. Thanks for the response.
https://linustechtips.com/topic/1163900-regarding-argb-cases/#findComment-13367340
Image result for very good sir gif
https://linustechtips.com/topic/1163900-regarding-argb-cases/#findComment-13367639
