So I have this recently bought gpu "Sapphire RX580 Nitro+ 8gb Special Edition". It requires a 8 pin and a 6 pin connector. But my PSU "Dell 525w 6w651" of the Precision T3500 has only 1*6 pin connector.
Before I had a MSI Gtx 560 SE ,Which required 2*6 pin connectors. I had an adaptor SATA to 6pin and it worked exellently without any issues for over 3 years.
But as I recently(after buying rx580) came to know that Sata only provides 50w on 12v.(That's why gtx 560 worked well.)
But for RX580, I was thinking maybe if I could use an adaptor 6pin to eight pin for the 1*6 pin psu PCI-E and use the SATA to 6pin to power it..
I don't have budget to buy a new PSU at the moment.
So, Can I run this for say what 2-3 months.
I am aware of this thing also that if power supply need to use adaptors means its not built for such condition.But I need to wait for making budget for New suitable psu.
Thanks.
https://linustechtips.com/topic/1163543-power-supply/
Do not use that psu.
Corsair cx 450-550w is decent.
Be quiet 450w pure power 11 is decent too
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1163543-power-supply/#findComment-13361752
Do not use SATA > PCIe adapters. Very bad idea.
The CX450 only has a single 8pin PCIe connector. He'll need the CX550 for the two PCIe connectors the card uses.
https://linustechtips.com/topic/1163543-power-supply/#findComment-13361767
