While I was using my other laptop just watching some videos and later something happened it bsod I was so shocked and later when I opened it , it was so freaking slow and when it was already on windows screen everytime I press something just a little bit of icon it will lag and I tried to ctrl+alt+delete but nothing happens just after 10 mins of waiting the programs opened even the task mesenger but its useless it so slow it cant do anything I need help
Alone.
https://linustechtips.com/topic/116313-need-help/
Turn it off. Then leave it for a bit. Then turn it back on.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/116313-need-help/#findComment-1554264
Re-seat the RAM, maybe use a pair of unused RAM modules and HDD. Not quite sure what's happening.
He's done it already, but trying again won't do any harm.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/116313-need-help/#findComment-1554279
If you're tech savy enough running linux off a USB flash drive can determine if the problem is hardware or software.
My rig: 2600k(4.2 GHz) w/ Cooler Master hyper 212+, Gigabyte Z68-UD3H-B3, Powercolor 7870 xt(1100/1500) w/AIO mod,
8GB DDR3 1600, 120GB Kingston HyperX 3K SSD, 1TB Seagate, Antec earthwatts 430, NZXT H2
Verified max overclock, just for kicks: http://valid.canardpc.com/show_oc.php?id=2609399
https://linustechtips.com/topic/116313-need-help/#findComment-1554289
I didn't get that from what he said, he said he closed it and opened it again. My laptop has started to develop a problem where it doesn't actually sleep, it just freezes but the screen stays off when you open it.
Holding down the power button and letting it sit for a few minutes then turning it back on helps. It could be a similar issue.
Though I have blame mine on Chrome. It only happens when it's been running.
https://linustechtips.com/topic/116313-need-help/#findComment-1554309
Well I have my laptop to shut down when I close it, you can change it in the power settings.
https://linustechtips.com/topic/116313-need-help/#findComment-1554327
Yes I know. But if he's having issues it might not have.
https://linustechtips.com/topic/116313-need-help/#findComment-1554357
Well, idk, I can advise him to re-seat the RAM, use other RAM and/or another HDD.
https://linustechtips.com/topic/116313-need-help/#findComment-1554363
was it videos on the web? then maybe.
A dodgy flash player can crash your system. I have had that problem.  It can lock up the whole system or crash it. and sometimes both. :angry:
Some fixes:
update/reinstall everything, yep even plugins. (i am talking about internet browsers/plugins and anything else associated with them.)
disbale plugins on your browser.
disable hardware acceleration.
Change browsers. Firefox/chrome/safari/IE..others.
If it was RAM, I would imagine you would have more erratic problems. but reseat it like stated above
CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
https://linustechtips.com/topic/116313-need-help/#findComment-1554397
