13 minutes ago, SladeDJWilson said:
I have a mid range pc with i3 9100F, 16Gigs ram, RX 570 4GB
All the games I play worked without any lag or frame drops like a week ago.
Now games are lagging and stuttering I don't know why can someone help me please
Could be driver instabillity, try DDU and then download and install new drivers for your graphics card.
CPU: i5 4670k @4.1ghz | GPU: Gigabyte Geforce GTX 1060 G1 Gaming 6GB | MB: Gigabyte Z97P-D3H | RAM: 4x4GB Generic | SSD: Gigabyte 240GB
PSU: Antec High Current Gamer 650 watt | Case: Cougar MX330G
https://linustechtips.com/topic/1162250-need-help/#findComment-13351129
1 minute ago, SladeDJWilson said:
What's DDU
Display Driver Uninstaller.
i'll attach a link for you.
https://linustechtips.com/topic/1162250-need-help/#findComment-13351138
What's DDU
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1162250-need-help/#findComment-13351140
Just now, the heck with this said:
hahah i just did the same heheheh
XD XD I saw
https://linustechtips.com/topic/1162250-need-help/#findComment-13351144
? Are they online games, or is it also lagging in offline games? What exactly have you changed since a week ago? Do you have the latest version of your Operating System, GPU, and bios?
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1162250-need-help/#findComment-13351167
Offline games
I play cricket 19 and RDR2
Used to 60 and 40 FPS
But now I'm getting 33-40 and 25 FPS
Windows 10
AMD RX 570 4 GB Gigabyte Gaming Edition
https://linustechtips.com/topic/1162250-need-help/#findComment-13351189
2 minutes ago, SladeDJWilson said:
Offline games
Windows 10
May be driver instabillity then.
Try and follow these steps and see if it maybe fixes your issue.
https://linustechtips.com/topic/1162250-need-help/#findComment-13351193
@SladeDJWilson
Well if the GPU drivers are the issue, AMD recommends doing a factory reset. He can do this in the adrenaline software itself in the settings menu. It will remove all settings and all previous drivers.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1162250-need-help/#findComment-13351207
10 minutes ago, BlackManINC said:
@SladeDJWilson
That'll be the best course to follow.
https://linustechtips.com/topic/1162250-need-help/#findComment-13351228
1 hour ago, the heck with this said:
internal lag ????
Lag has become universal term for all issues with games.
Besides GPU drivers, this could be cause by Windows update or some new background process running. Things not just change to anything without cause.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1162250-need-help/#findComment-13351441
WELL I USE THE SIMPLE ELIMINATION FACTOR I ASUME THAT THE OS IS IT  SHOULD RUN  AND IM LOOKING 1ST ON THE GPU ITSELF THEN YOU GO TO PERIPHERALS THES THE OS THATS JUST HOW I DO THINGS NOT THAT YOU ARE WRONG BUT ONE AT A TIME MUST BE ELIMINATED IN ORDER TO FIND THE PROBLEM THEN WE CAN FIGURE OUT THE MEDICE
https://linustechtips.com/topic/1162250-need-help/#findComment-13351453
sorry for my capitals
https://linustechtips.com/topic/1162250-need-help/#findComment-13351454
