What kernel does Wondows10 Use?
Go to solution Solved by homeap5,
NT 10.0. But imo it should be named NT 6.4 (win 8.1 was 6.3).
2 minutes ago, Xaxor said:
Hi,
I am trying to write a University Paper on operating systems and I am struggling to find what kernel windows10 uses/used upon release as every search result I get is about how windows 10 is getting a linux kernel. (Any references would be helpful).
Hello,
Wikipedia says "Kernel type : Hybrid (Windows NT)".
It uses a Windows NT - kernel.
