hey guys - I was just wondering - I have an old rig that I lost the power plug for and Ive found an identical one that is in my rice cooker, would that work to plug into the old computers PSU or will it catch fire somehow.
Old rig:
GTX 1080ti
I5 4690k
16gb ram
Corsair RM1000
Plan on giving it to my Mrs but dont want it to...you know...burn things.
https://linustechtips.com/topic/1161750-power-supply-cable/
Ah you're talking about the "Kettle Lead" or C13 lead.
You'll be fine.
I'm an IT System Admin with 15+ years worth of XP, plus I've been tinkering computers since I was old enough to hold a screwdriver, so I usually know what I'm talking about.
https://linustechtips.com/topic/1161750-power-supply-cable/#findComment-13346297
If it's a normal C13 plug, it will work.
https://linustechtips.com/topic/1161750-power-supply-cable/#findComment-13346299
3 minutes ago, Nasbirhu said:
Yeah! Kettle lead. Thank you :) How do I know its C13?
If it looks like IEC C13 you'll be fine.
https://linustechtips.com/topic/1161750-power-supply-cable/#findComment-13346318
1 minute ago, Nasbirhu said:
One last question - do the amp or volt of the lead matter? It says 10A 250v
If it were a really low rating it might matter (as in 1-2 amp, but I don't even know if those exist) but that's perfectly fine. A rice cooker draws significantly more power than a computer.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1161750-power-supply-cable/#findComment-13346342
Unless your PSU is pulling in more than 2500 watts you're good :)
https://linustechtips.com/topic/1161750-power-supply-cable/#findComment-13346349
