what is the minimum acoustic limit in radion software and will i get better performance and or cooling with it all the way up or down
Solved by BobVonBob,
When your card's clock speed is below the minimum acoustic limit frequency your fans will run at the minimum speed to keep them quiet. Above that frequency the fans will ramp up to keep the GPU cool. It's a trade off between slightly higher temps and quietness when the card isn't doing anything and isn't hot anyway.
Featured Topics
Davidhelp ·
Gessler555 ·
Justbon321 ·
Posted in Peripherals13 -
stefanmz ·
Posted in Programs, Apps and Websites19 -
Captain LeFwee ·
Posted in Networking6 -
11
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
