case for a semi silent build
RuJuRa
I need a case for a semi silent build and it will be my first build so maiby a BIT bigger than needed, also I am on a pretty tight budget, 100 is okay, 150 is a little expensive and 200 is WAY too much! But thanks ahead!
Define R6.
Or buy low power components that can be passively cooled, that's silent.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
20 minutes ago, jstudrawa said:
Define R6.
I have to fit in a R3600 and thats not gonna passively cool it self so thats not a option and define r6 is a little expensive, is there a cheaper alternative maiby? I don't have that much budget :(
1 minute ago, lafrente said:
nzxt s340 or s340 elite
They aren't selling it at the place where I want to buy it  from (arvutitark.ee)
You didn't tell us your budget, so I suggested a very viable case.
Also, where are you?
We can't just read your mind as to your money situation or where you are... sure we can assume based on your user name, but that's racial profiling and usually incorrect :)
OnePlus:
Other Tech:
I did tell the budget: 100 is okay, 150 a little expensive. But 200 way too much! And a thing I did forget is where I am ordering from, its an Estonian site called arvutitark.ee
And it was a very good suggestion, It was my first choice but then it was a bit too expensive.
Btw thanks for the suggestion :)
Location and currency matters. The R6 is anywhere from $110-150 USD in America, but in other countries it could be more. Hence why the R6 isboth viable and not viable. Details are important!
Here's a Fractal Design Define C / Define R6 clone
https://arvutitark.ee/est/tootekataloog/Arvutikomponendid-Korpused-Mid-Tower-korpused/Kolink-Tranuility-Midi-Tower-schwarz-gedammt-474636
A corsair 270R
https://arvutitark.ee/est/tootekataloog/Arvutikomponendid-Korpused-Mid-Tower-korpused/CORSAIR-Carbide-270R-solid-Side-ATX-Case-CC-9011106-WW-259194
Pure base 600. This one really focuses on noise suppression at the cost of airflow, so if you're looking to overclock or have a work station, this might not be the best option.
https://arvutitark.ee/est/tootekataloog/Arvutikomponendid-Korpused-Mid-Tower-korpused/Be-uiet-PURE-BASE-600-must-BG021-266829
The original Define S for 80 euro is still a good deal
https://arvutitark.ee/est/tootekataloog/Arvutikomponendid-Korpused-Mid-Tower-korpused/FRACTAL-DESIGN-Define-S-Black-FD-CA-DEF-S-BK-161656
However in the 130-150 euro range we can find the newer Define S2 and the Phanteks P600S, both of which are great cases for both silence and airflow (and really selectable with the P600S with the removable front plate)
https://arvutitark.ee/est/tootekataloog/Arvutikomponendid-Korpused-Mid-Tower-korpused/Fractal-Design-Computer-housing-Define-S2-valge-390223
https://arvutitark.ee/est/tootekataloog/Arvutikomponendid-Korpused-Mid-Tower-korpused/PHANTEKS-Eclipse-P600S-Silent-Midi-Tower-geschlossen-schwarz-405478
Keep in mind; three things contribute more to system noise than any other components; fans, coil whine and Hard drives. Cases like the ones I've listed can really help with Hard drive and coil whine noise since they have noise suppression foam panels that can help block higher pitched frequencies, but when it comes to fans, your choice of fan as well as how you regulate them are the most important parts in making a "silent" case (that doesnt overheat!) Hence, you can make a case that's all mesh really quiet by choosing good fans and/or controlling how fast they spin, as demonstrated here:
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
A corsair 270R
This was SUPER useful, thank you so much! This has basically finalized my first builds basket!
