GPU not clicking into place?
4 minutes ago, ShadowSuave said:Yeah, it slides past the mobo, I actually wasn't aware of the holes on the other side(thanks for pointing that out) but it seems that they're also in place. Not sure exactly what's stopping this from clicking in does it look unlocked in the pic?
I cant tell, its hard to see and am not fammiliar with the exact boards latch type (theres variations of those).
Thus "U" tiny cutout on the card does seem to have 1 or 2mm spare room to go down, but again not sure.
With the card out can you move the latch by hand (if not, or if it just falls flat again) it might be the latch at fault?
Or, (and do double check the card is straight) its just a tight slot and the card needs a gentle last push for it to close - however: proceed wjth caution; if your not a experiencend builder and not sure how much is gentle and how much is abnormal then dont try that
