Hi, i’ve asambled today my Pc, all parts brand new, It is an ryzen 5 2600, 16gb ram of 3200, an Rx 580 4gb, and a 650w source. After asamblation my Pc does not post. The qwestion is: what can i do to make It post? I’ve put inside a speaker and It beeps one time short, and 3 times long. Any ideea what to do?
thx!
https://linustechtips.com/topic/1158874-ryzen-5-2600-not-posting/
thx!
1. What motherboard are you using?
2. Are there ant POST codes/LEDs on the board?
3. Are you plugged into the videocard?
4. Have you tried another monitor?
5. Have you tried letting it sit for a couple minutes?
6. Have you looked up what the post codes/beeps mean on this board?
A pcpartpicker list helps a ton
Primary PC:
PSU tier list
How many watts do I need?
thx!
The speaker sound is a “beep code”. It is telling you the machine is having a problem and trying to tell you where the problem is.  The manual for your motherboard should tell you what that beep code means.
