Converting wired ethernet printer to wireless
This should be fun. I have a restaurant, which is an amalgamation of three different buildings kind of merged into one as we've expanded and has had very dodgy repair work done. The network setup is HORRIBLE, and I can't make heads or tails of it. The wired network has always been incredibly unreliable (water gets into the wall, and I'm assuming rodents can too and damage wires), the whole place is badly wired, has dirty power etc. Our POS system barely works as is because of initial poor configuration.
Recently, our wired connection to our thermal kitchen printer has failed, which is a fairly serious problem as we can no longer send orders to the kitchen, a fairly important aspect of a restaurant.
  • Medium term, the solution is to change POS software and have somebody come out and set it up from scratch, but we are in a rural area, and the cost to get someone out here to do it, plus the hardware needed is about $20k.
  • Re-running the damaged Ethernet cable is not an option due to genius design, I would have to tear down a wall, which would cost a tonne and render a portion of the restaurant unusable for seating. I also can't realistically run it outside of the wall for a few reasons (which could be worked around cheaply, but at a lot of effort).
  • Powerline adapters are not an option as the server PC and the printer are on completely different circuits.
  • I have a point of sale terminal close to the kitchen, so I could in theory run a cable from the terminal to the printer, but the terminal only has a spare USB port.
So that leaves me with converting the printer to run over our (rock solid) WiFi connection. The printer is an Epson TM-U220B. It has an ethernet connection ONLY, no USB.
Are there any wireless print servers or bridges that would allow me to connect the ethernet-only printer to Wifi?
Or failing that, to connect it to USB (I'm not sure the POS software supports USB printers, so that could create more problems).
There are items like this you can buy...
https://www.amazon.com/IOGEAR-Universal-Ethernet-Adapter-GWU627/dp/B018YPWORE/?tag=aboutcom02lifewire-20&ascsubtag=2377741|n0f460ec5e190458f95fd8850dd16499f13
Forgive me if I don't eat there... you have bigger problems than not getting an order some 15-20 feet to the kitchen wirelessly :)
"(water gets into the wall, and I'm assuming rodents can too and damage wires)"
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Haha it's fine dining and very well known - it's also perfectly hygienic (perfect health inspection scores). We're also fully booked until May so no room for you anyway!
But because it's a collection of buildings that have been poorly joined together to make, there is alot of space between the walls that are accessible somehow.
Rodents do not get into the restaurant itself, but have access to the crawl space (I assume, they might not, but there's a lot of possums in the surrounding woods that get on the roof sometimes).
Thanks for the device, the distance is actual several hundred feet. It doesn't seem to be available in my country, but I will look for something similar.
Good to know!  Glad your restaurant is doing well!
If it's that far, you may need to check your wifi is covering as well.  I don't know much running an outdoor cat6 cable would cost, but may be viable depending on country/region.
OnePlus Ecosystem:
3D Printing:
