Storage drive not detected
Go to solution Solved by AzrealNoctis,
30 minutes ago, AzrealNoctis said:
Oh, didn't see that part when I read the manual, must've skipped over it. I'll do that and post again what happens
34 minutes ago, minibois said:
Thanks alot, now everything is working fine so far, thanks alot for the help!??
3 minutes ago, AzrealNoctis said:
So I've gotten all the way to installing Windows and the system says there is no drive to install Windows to, but there is a fresh sabrent m.2 2tb SSD in my setup rn. What may be the problem?
What motherboard do you have and which of the M.2 slots are you using?
Just now, Electronics Wizardy said:
does the drive show up in the bios?
full system specs?
Asus x470f gaming with an athelon proceser for bios updating, gtx 1660 overclocked super from Asus, and no it's not even in the bios, maybe I knocked it loose by accident, but I don't think I did, I'll check
what ssd?
what m.2 slot are you using?
It's a Asus x470f gaming and I'm using the one that doesn't say sata, sorry not sure of the exact name of it
What CPU do you have?
EDIT: oh you said Ahtlon above. Those don't support PCIE SSD's.
It's an athelon 200ge, it's only in there so I can update the bios
Just saw you mentioned it above. Ahtlon doesn't support NVME/PCIE SSD's. I edited my comment:
Oh, crap, now what do I do?
Get a different SSD or different CPU
If you have a dedicated videocard, just get something like a 1600 AF for  example. Depends on what you have already.
You gave me an idea, well two ideas, 1:can I install Windows to an external drive update the bios swap cpu's then copy the os to the ssd? Or I know I have an old hard drive from a laptop I don't use anymore, could that work?
I don't think I am following you here.. You want to update the BIOS (presumably to use a 3rd gen Ryzen CPU?), so that is why you have the Athlon. Then why do you need Windows and why do you need the SSD?
Just put the BIOS file on a USB drive and update from the BIOS.
But to answer your questions:
Can't recommend Windows on an external drive, but I am not understanding what you are asking here.
Wait in regards to the first statement, I wasn't aware this board even had that feature, it didn't say I could update the bios with a USB, but let me try that and ill see what happens
https://dlcdnets.asus.com/pub/ASUS/mb/SocketAM4/ROG_STRIX-X470-F-GAMING/E14093_ROG_STRIX_X470-F_GAMING_UM_V2_WEB.pdf
See page 3-23
