Will it fit
Go to solution Solved by minibois,
5 minutes ago, Tuck2674 said:
I looking at buying the Phanteks PH-ES518XTG_DGS01 Enthoo Evolv X ATX Case and the Noctua NH-D 14. I know this thing is huge my question is will it fit in the case without issue?
Case: 190mm clearance for the CPU cooler
CPU cooler: 160mm tall
It will fit
The specs on the Phanteks website say the CPU clearance for that case is 190mm, and the height of the NH-D14 is 160mm, so yes it should fit.
https://linustechtips.com/topic/1157874-will-it-fit/#findComment-13314737
It will fit
https://linustechtips.com/topic/1157874-will-it-fit/#findComment-13314738
Read the "Field" Manual?
Mine tells me exactly what the max cooler height is, I went a couple of mm less just to be sure.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/1157874-will-it-fit/#findComment-13314739
Yes, it fits but I wouldn't recommend the NH-D14 if you don't have it already. The design is a bit outdated and there are generally better / cheaper options available.
https://linustechtips.com/topic/1157874-will-it-fit/#findComment-13325967
  • 2 weeks later...
the NH-D14 is an old design and has been replaced with the NH-D14S which comes with a single fan instead of a double. They claim it was redesigned so that a single fan on it works nearly as well as the older double. But you can still add a second fan and they even include the extra clips. I just got one for my rebuild that is in a 4u rack case.
https://linustechtips.com/topic/1157874-will-it-fit/#findComment-13350456
