need help finding a certain case for sale
m0oble
found a case i like on amazon but its not on sale or in stock
https://www.amazon.com/InWin-305-White-Computer-Tempered/dp/B0753NH32N/ref=cm_cr_arp_d_product_top?ie=UTF8&th=1
if you can find this case on amazon for sale that'd be appreciated thanks in advance
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
750w dragon or something psu idk
i found them on inwin's website but i'd like to order on amazon instead, unless i cant find it
pc specs:
r5 3600
16gb ddr4 3200mhz
b450 tomahawk max
rx 6600xt
1tb ssd + 6tb hdd
meshify c
I'm guessing you're in the US since you linked amazon.com, but if you happen to be in the UK, Overclockers have it (the black one - https://www.overclockers.co.uk/in-win-305-midi-tower-gaming-case-black-window-ca-082-iw.html).
You could also try contacting amazon support to ask whether they will have it in stock any time soon (since they are very responsive, but likely won't be able to tell you).
However, looking at price tracking website (https://camelcamelcamel.com/InWin-305-Black-Computer-Tempered/product/B0753NH32N), looks like they haven't stocked it since Feb last year (assuming the tracker is correct), in which case getting it on Amazon seems unlikely.
Otherwise your best bet is to finding somewhere else on google shopping search or getting it from InWin directly. You could also see if Overclockers deliver to US and which option works out cheapest.
All signs point to a discontinued case (I found one Newegg review from the First month of 2018, so this case has been gone for a while it seems). Your best bet is to import it from out of the country such as that UK link @Muwatallis provided.
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
