Resolution problem with my new monitor 49" ultrawide samsung
hakoops
Go to solution Solved by hakoops,
Yehhh thank you for your hlep it works you can check.
Hello everyone,
I'm having some resolution problem with my new monitor samsung 49" ultrawide CHG90 I cant't find the right resolution i usin actually 2560 x 1440 at 100%.
I have a windows 10 last update and a GTX Titan last version driver.
what can I do ?
Thanks.
Thank you for your fast answer this is what I get at 3840 x 1080, is the GTX titan enough for the monitor maybe ???
Yeah, resolution for that monitor should be 3840x1080p, try chaning the scaling mode in Nvidia control panel to full screen or aspect ratio
Right click desktop>nvidia control panel>display tab>adjust desktop size and position and then try the scaling modes
